orin76
I need to find the best value for money graphics card for driving 2 HP LP3065 30" dual-link DVI monitors at a minimum resolution of 1600x1200. From what I can tell, there are plenty of cards that support a single dual-link DVI monitor, but once you add the second, the max possible resolution on one of the monitors is limited to 1280x960.
I have already tried the following:
Nvidia Quadro FX50
Nvida Quadro NVS440
I've looked at the Quadro FX4600 specs and it seems to support 2 dual-link DVI outputs, but it retails for almost $2000.00!!!
Any advice??
Nvidia Quadro FX50
Nvida Quadro NVS440
Any advice??
