need help configuring cisco 877 adsl router
passive
Hi
I want to configure my old Cisco 877 adsl router to bridge mode
Please I need detailed step by step help with this... what I know about Cisco and console is very dangerous.
If I reset the router what will it change my ip settings to? 192.168.0.1 or 10.0.0.2? Router still configured with my old static solution which I’m no longer using.
Can I connect via a web interface or must it be from telnet or via console cable.
Thanks in advance
1) Find someone who knows how to config a cisco router. Most are done via the CLI
2) You could try and config the router with Cisco SDM Software...
