Need help diagnosing adsl line dropping/packet loss
User4456
Problem: Line dropping every few minutes. A lot of packet loss at times.
Equipment:
- TP-LINK WD4300 Wifi Router
- Billion 800VGT Adsl modem
Line attenuation: 43 down; 29 up
SNR: 16 down; 12 up
Here's the tracert results that I get. It doesn't matter what address I use. Hop 3 always times out.
Hop 1- Wifi router
Hop 2- Adsl modem
Hop 3 - ??????????????????????????????????
Tracing route to www.google.com [173.194.46.112]
over a maximum of 30 hops:
1 1 ms 1 ms <1 ms 192.168.0.1
2 2 ms 1 ms 1 ms 10.0.0.2
3 * * * Request timed out.
4 18 ms 136 ms 53 ms cdsl2-rba-vl2766-ipc.ip.isnet.net [196.38.73.86]
5 10 ms 11 ms 12 ms 196.38.73.85
6 12 ms 11 ms 10 ms cdsl2-rba-vl150.ip.isnet.net [196.38.73.9]
7 13 ms 14 ms 12 ms core2-pkl-t0-7-0-0.ip.isnet.net [168.209.1.163]
8 56 ms 10 ms 19 ms 168.209.1.179
9 12 ms 13 ms 12 ms 72.14.205.16
10 178 ms 178 ms 179 ms 66.249.95.8
11 174 ms 201 ms 174 ms 216.239.51.7
12 266 ms 257 ms 288 ms 209.85.143.122
13 274 ms 272 ms 272 ms 209.85.143.115
14 265 ms 266 ms 269 ms 216.239.50.237
15 272 ms 272 ms 274 ms 209.85.245.225
16 265 ms 265 ms 265 ms ord08s13-in-f16.1e100.net [173.194.46.112]
Trace complete.
What is the problem with hop 3? Is that the little Telkom blue SDP switch outside our house on the street?
The results are the same with two different routers, and two different ISPs. Line still drops, tracert results similar. I've also had a Telkom techie try change my DSLAM at the exchange which improved attenuation but did not solve the dropping/packet loss problem.
Any help finding the problem would be appreciated. Or at least helping me to point the techie in the right direction.
