Need help fast please regarding laptop for cad
Im looking for the same laptop, did you manage to find/choose something?
Yup that mecer one looks good. I think they are going with that. Sandy bride cpu and 8gb memory with free windows 7 64 bit :D. They do not offer free windows though.
The Mecer without Windows is an awesome option if your work place has a Microsoft Volume License agreement, because then you can get Windows 7 Enterprise edition on your laptop without wasting the DSP/OEM license :)
From what I can see, it has no dedicated GPU which is a major requirement for CAD
GeForce GT-540M with 1GB DDR3 dedicated graphics
Sorry, reread and actually read this time ;)
or how would you decipher this
Embedded nVidia GeForce GT-540M with 1GB DDR3 dedicated graphics and nvidia optimus with Intel HD shared graphic
Is it two cards? Integrated and dedicated? I see several laptops that now do that, allowing you to switch between for stamina or speed. I dunno. Anyhow a decent graphics card is essential.
It has two GPU's. Under higher load the processing is offloaded from the Intel gpu to the nVidia gpu. While just surfing, reading email, using office apps etc the nVidia GPU is powered down. This feature is there to save power and battery life.
http://www.nvidia.com/object/optimus_technology.html
http://en.wikipedia.org/wiki/Nvidia_Optimus
Thanks, im thinking ill just uninstall the intel Driver so it permanently uses the proper GPU. Battery life on a 17" Full HD beasty isnt really a major concern for me.
I'm not sure you can do that as the nVidia GPU uses the Intel GPU to output the display. I have read that on some laptops there is a option in the BIOS to disable one of the GPUs but I can't recall which one it disables and not all laptops have this feature.
I don't really see the need to disable it though, it works kinda like a CPUs speedstep feature where it downclocks & powers off unused cores.
Thanks for the info, ill test it out when the mach gets here. Should be about a week.
