need help for MEGA105WR
lakshmanvepuri
Hi Friends.
Please can u please send me what are the configurations to be made for MEGA105WR for connecting laptop thru wireless mode.
I tried thru lot of ways but couldn't..
Can u please send me the security settings also.
Thanks & Regards,
Lakshman
Reset the device by holding in the reset button at the back for about 20 seconds while powering on, then go through the setup wizard - it's all explained there. And with many of those routers (100's & 105's) no matter what custom wireless key you try to insert, the stupid device still uses the factory-set key - which is the things mac address, which is the number on the bottom sticker. This little piece of telkom brilliance has stumped many before you, trust me.
Edit: Oh, and don't be surprised if you can't find this post - by the time you look again, it may well have been moved from "Broadband & IT news articles" to somewhere else...
If you not willing to reboot the modem try this
log on http://10.0.0.2 enter username and password default "admin" for both
click wireless top center more to the right. click setup on the left hand side NOT THE ONE ON TOP. change the ssid to anything maybe your name e.g. "peter's network" click APPLY. the click on security on the left NOT THE ONE ON TOP. select wep as a wireless security. tick the checkbox enable wep wireless security authentication stays open type in a 10 digit password under encryption key e.g. "0123456789" click apply then save settings then restart access point
wireless setup settings now complete;)
-yes I know wpa is more secure but I am assuming it did not work :p
