Need help setting up two accounts on D-Link 504t router
stefan9
Pretoria
Hi guys. Need help. I got an afrihost account now. I want to add it to my router together with my mweb account. But when creating a new account when I try to apply it gives me the following error: Says VPI and VCI already assigned. MWEB and AFrihost seem to use the same settings. Can I use something like 9 and 36 or will that not work??
yeah his right need to bridge the connection you cant use the same VCI and VPI ports as you have on the other your main account is on 0v1 correct
Anybody willing to give me a run down what I need to do. Ok I understand in the router I change to bridge mode.
But how do I setup the connections??
Also can anyone recommend a decent adsl wired router. Just found this one isn't saving the second settings. When restarting it loses it each time.
try incredible corruption
dont remember names of the pc shops i saw in menlyn even though i go there lots
went to website and saw PC Pro Shop they might help its in menlyn shopping centre
if not i'm coming to Pta anyway next week and i can see if i can find anything
Got it sorted. For some reason only I will know I kept forgetting to press the save all button.:erm:
Bot got everything working now.
Explain?
or did you create pppoe dailup connections on the desktop ?
My router wasn't saving the settings since I forget to press the save all tab. Once I figured that out I put both connections into bridge mode and created pppoe dialup connections.
