shiverz
- Nov 1, 2013
HOW HOW HOW HOW HOW?Did yo came right , I managed to root my suster's one
Screen and battery life decent? Considering the price... No lag due to low RAM?yes the rooting worked , now a very nice tablet in the price range without all the advertising and auto start apps . -![]()
I did a mini review about it when I bought it around December last year.Screen and battery life decent? Considering the price... No lag due to low RAM?
Thanks, man. Looks decent.I did a mini review about it when I bought it around December last year.
http://sagamer.co.za/forum/showthread.php?p=2724919
The low screen resolution is the only real downside for me for gaming like CoC. Obviously it will struggle with graphic intensive games. Also you will need a memory card cos 8 gigs built in is not enough. Otherwise for Web browsing, movies & series and YouTube, which is what I got it for, it's brilliant. There is no lag in using any of the aforementioned apps or in Nova Launcher.
4000mAh is not much for a tablet. I usually charge it once every two days.
I'd suggest playing with the demo model in a store before buying. You're definitely going to feel the difference in PPI moving to a bigger screen and going from quad core to dual core, especially if you are going to be gaming on it.Thanks, man. Looks decent.
Compared to the Samsung Tab E which is twice the cost, has a smaller screen, and an older OS.
I'm currently using the Huawei Mediapad T1 8.0 inch which is solid. Looking for something with a bigger screen.
Yes I'll definitely try that. Didn't see a demo version at any of the VC stores I've been in lately but I'll check.I'd suggest playing with the demo model in a store before buying. You're definitely going to feel the difference in PPI moving to a bigger screen and going from quad core to dual core, especially if you are going to be gaming on it.
