DarkWhisperer
My PC was incredibly dusty and the fans were starting to grind. So I knew a spring cleaning was required. Im quite familiar with the inside of a PC, so I had no problems taking it apart, cleaning off the dust (gotta love canned air), and putting it all back together. However, on startup, the power comes on for about 2 seconds, and then goes off for about 4 seconds, then on again for 2 seconds, and then off, and round and round. So somethings wrong. Removed all uneccesary components like HDD's & graphics to try to get it to POST. But no luck. Tried using just 1 stick of RAM, and swapping those around, no luck. So either its my CPU or motherboard thats gone.
So the question is, which one is it and how do I tell? Can a motherboard power up and idle without a CPU? Is there something else I should be looking at, like my PSU perhaps?
