I.am.Sam
Hi guys
I need to upgrade my ancient desktop so i need help with parts
My old pc was an amd 2.8 ghz single processor with a 6600gt card and like 1.5gig ram and 80 gig hdd
i want to use the same chassis and power supply so i just want to add the new parts in there
I have seen these components and was wondering if someone could help advice if they would fit together and if this would be a good build ...pc to be used mainly for work purposes and to watch movies and stuff on it
1 -Intel Core i5 2300 Processor-2.80GHz, Socket 1155, 6MB L3, 2.0Gb/s DMI Interface (R1229 )
2 - ASUS P8H61-M LE - CORE I5 AND CORE I3 PROCESSORS (SUPPORTS INTEL 32NM CPU)- MICRO ATX FORM FACTOR, 2X DDR3 (MAX 16GB 1333MHZ), 1X PCI EXPRESS 2.0 X16, 2X PCI EXPRESS 2.0 X1, 1X PCI, 4X SATA 3.0GB/S, 10X USB 2.0, 10/100/1000 GB LAN, REALTEK ALC887 8 CHANNEL HIGH DEF AUDIO (R569)
3 - Kingston 4.0GB DDR3 1333MHZ Non ECC Desktop Memory Module(PC3-10600 240-Pin 2 Rank DIMM)CL9 (R296)
4 -Spinpoint 1.0 TB Serial ATA Hard Drive ( SATA 3.0Gb/s, 7200rpm, 32MB Cache) (R449)
5 - Point Of View GF430 1GB DDR3 64-BIT, Core speed 700 MHz, Memory Speed 1000 MHz, Shader clock 1400 MHz ( R479 ) ( reason this card is hdmi out )
the prices are excl vat ....if anyones knows cheaper please let me know
your help would be highly appreciated
