Need help with fiber setup. Router to ONT.
Lukitz
I recently moved house and this house has a different setup. I need help correctly connecting the router to the ONT. Please see the attached images.
The yellow cable is currently going from the Fibre Termination unit into the SAT port. Then another yellow cable is going from the DATA port into the black box which is connected to the router via an ethernet cable.
Please tell me if I'm doing something wrong here. Cool ideas is frustrating to communicate with, they don't know what to do and keep referring me to ClearAccess. The fibre was working great for the previous owner.
I stand corrected but, it the line from clear access was active and working, the broadband light on the black box connecting to the router should be lit and green, like the power and ethernet lights..
If I am correct, clear access will have to help you fix whatever the cause of the broadband light not being green..
