Need help with iburst
DarthCat
Some place
I want to connect iburst with more than one pc with my wireless router. What must I do?
So you have an iBurst router which has wireless?
If so then just connect to the router via wireless.
If you mean you have a wireless router / AP and want to broadcast the iBurst through that, I don't think its possible.
I am using a program called... Connectify to share my internet connection (iBurst USB modem connected to a netbook).
It broadcasts like a wireless router and my PC and phone etc. all connect to the netbook :)
Perhaps give that a try?
Ideally you need a desktop modem for this. You will then require a "broadband router". This device looks like an ADSL router but has an Ethernet WAN port in the place of the port for the telephone line.
Plug the desktop modem into the WAN port. Enter your username and password in the PPPoE settings on the router and it should work.
Im using a desktop modem and dsl router. At the moment I can only make a connection from one pc at a time. A second pc then don't want to connect. Why?
Do you have the router in bridged mode and are you trying to establish PPPoE connections from each PC?
You need to configure the router to establish the PPPoE connection, you don't need to do anything on each PC.
You need a WAN/Broadband router to use with a desktop iburst modem.
If you called iburst they should tell you to get a Linksys WAN router.
