Need help with old laptop...net boot advice
MeNeZ
Sup
I've got a big problem with an old laptop I bought. (I knew its condition when I bought it.) Its a P3 Compaq Armada full of virus's.
I want to format it but I cant boot from CD. It cant seem to see the CD-Rom on boot. From the brief period I spent looking online I saw that it may be a motherboard/bios limitation...or I was thinking maybe a boot sector virus.
I cant install when in windows either because it bombs out and I dont really want 2 partitions, 2k & xP
I bought 3 other laptops too which are different models & I havent had any problems with. It can only see the option to network boot...
Does anyone know how to setup a PXE net boot or alike? At my old place all that stuff was in place and we could use Altiris for example but I dont have anything like that at my current place and Im puzzling on how to format this thing :/
I could maybe try that HDD in another working machine but I dont think that will work to well because of differing models. (same brand)
any ideas??
EDIT: I have changed the bios boot order to boot from CD 1st but no luck
Sorry for double post ^.^
Looks like the CD-Rom is buggered.
Can you try to connect an USB CD-Rom and install from there? Or try to get a mongo USB stick (1Gb), make it bootable and copy the windows install files on there?
I also have the same problem with a craptop I received for free... so it's just gathering dust atm.
I think the Ultimate Deployment Appliance may help both of you solve your problems (Provided those old laptops support PXE boot) I use it often, and I must say it works very well! Just get yourself a copy of VMWare Server (Free) and download, install and configure this appliance... It is pretty easy to configure and use!
Ay cool, tanx guyz! I'll try both. That VMware looks like a winner
Just one more question...(I havent had blady time to re-install yet)
Could a security policy prevent booting from cd to stop users from fiddling? These laptops were seriously locked down...
That would be set in your BIOS. When you boot up there's no OS loaded so there's no way a security policy could be applied.
Disable it in the BIOS and setup a BIOS password.
