Need help with series recording on DSTV
blackguyza
Heilbron, Free State
I have been recording my favourite series (a documentary about America) using a series recording option on DSTV and now that I have deleted some of the previous episodes, the recording does not continue.
The green symbol (R) continue to show on the program schedule but it doesn't change to a red button when the program has started playing. My main problem now is that it does doesn't allow me to do a new recording of even single episode of the series.
Best bet is to delete the series recording schedule from the menu and re-schedule the series recording - this has worked for me.
If you use the series recording option - does it record the repeats as well?
I have a PVR decoder form the beginning of 2010 and I don't have that function that I've seen - do I need to do a decoder update?
Also these decoders have a pin in order to do a upgrade - is there a default pin or should DSTV have provided me with one?
I have this model decoder - http://www.jump.co.za/products/prices/4560430-dstv-pvr-decoder-hd.htm
The silver one should have series based recirding, try updating it, and yes the pin is the same 9949
nope it doesnt record the repeats , well most of the time it doesnt, once in a while it gets confused :)
nope my dual view PVR does nothing of the sort?
what u mean by "our favourite series schedule" ???
only certain chanels have series based recordings, on the tv guide if the program as a green circle you can record the enttire series, when you set to record it will ask you if u want to record just this episode or the entire series
ok thanks guys but I have never seen this green circle since I bought my SD dual view PVR in dec2008. I have also checked the tv guide and have not seen said green circle?
so please give me a channel that has a green circle to check.
also how does one do a manual update? as my "DSD Upgrade" function is permanently greyed out??
SDPVRs don't have series recording, only HDPVRs do
The last SDPVR update was September IIRC, so it will be greyed out & update automatically when its available
