Ok, well for now lets rule out the SDPVR
You'll need a combination of HDPVRs and/or single view decoders (1110 or 1131)
You will obviously need enough LNB feeds, dual LNB + 2x8 multiswitch will do
Each "couple" of decoders will need a heartbeat cable between then, and you'll obviously need to get dish feeds to each room if the decoder is going to be in each room
Ok so let us take it like this: he has a hd pvr in the tv room.
Steps to take:
1. Buy another 1131 decoder.
2. Put new decoder in furthest room
3. Buy two sets of remote blasters
4. Install 2x8 multiswith
5. Take 2 feeds to primary decoder.
6. Then 1 feed gets pulled along with heartbeat cable to furthest room to secondary decoder.
6. Pull heartbeat cable rf in primary decoder to rf in secondary decoder tv in bedroom.
7. Connect room next to tv room via rf out to rf tv input.
8. Set up a set of remote blaster set one blaster in tv room and other blaster in bedroom.
9. Then do the same with furthest room and other bedroom.
10. Then connect rf out from secondary to the rf of tv in other room.
11. Put blaster in secondary room and then other blaster in other room.
Would this work?
Thanks Smurfatefrog may you blessed for your help!
