Hi,
I please need help setting up the following;
Samsung HT-D5350K home entertainment system
Samsung UA46D6600 TV
HD PVR
XBOX 360
All of the above with HDMI.
So what exactly do you need help with?
Can't you smell what the problem is? What's wrong with you!![]()
Just bear in mind that you will need an optical cable from the pvr to get surround sound. Doff, I know.
Surround sound over HDMI was introduced on the HDPVR over 2 years ago...
Then use TV optical out to home theatre optical in
Only stereo (2ch PCM), you wont get DD or DTS 5.1 passthrough from HDMI to optical (or HDMI ARC for that matter).Does sound get carried from Xbox/PVR through the TV to the HTIB? As in TV acts as a repeater?![]()
Yes, but if you read above, issue is two HDMI devices, zero HDMI input on HTB, just an optical.Why does it need sound over optical (devices → TV → HTIB)? Does the HTIB not support sound over HDMI / repeating?
