2428 Asus ML series ML229H 21.5" wide LED display with iPS technology ( true 178° wide viweing angle + real color ) , ring stand with ergo-fit II technology ( easy tilt adjustment by finger ) , LED touch-sensor buttons , 21mm slim , Full HD 1920x1080 (WUGA+) ; brightness- 250cd/m2 ; smart contrast ratio- 50000000:1 , response time- 5ms - d-sub+ HDMi or Dvi+ headphone out - 100x100mm vesa wall-mountable
8204 Asus PA246Q 24.1" wide lcd display with P-iPS technology ( true 178° wide viweing angle + real color + 98% of Adobe RGB coverage , pre-calibrated with a maximum ΔE less than 5 , 12-bit color look-up table for greater depth for each RGB colors , 1073.7million display colors ) , 4-way adjustable ( tilt+swivel+pivot+height ) stand , built-in USB hubs + 7-in-1 card reader , 20mm slim , Full HD 1920x1080 (WUGA+) ; brightness- 400cd/m2 ; contrast ratio- 50000:1 , response time- 6ms - d-d-sub+ Dvi+ DisplayPort+ HDMi+ headphone out - 100x100mm vesa wall-mountable
4387 Hp VM626A4 ZR22W , 21.5" wide lcd with iPS technology ( true 178° wide viweing angle + real color ) , 4-way adjustable ( tilt+swivel+pivot+height ) stand , 1920x1080 , brightness- 250cd/m2 ; contrast ratio- 1000:1 , response time- 8ms - DVI+ displayport + d-sub + 4x usb downstream hub ; 100x100mm vesa wall-mountable - 3 years warranty
6268 Hp VM633A4 ZR24W , 24" wide lcd with iPS technology ( true 178° wide viweing angle + real color ) , 4-way adjustable ( tilt+swivel+pivot+height ) stand , 1920x1200 (WUGA+) , brightness- 400cd/m2 ; contrast ratio- 1000:1 , response time- 5ms - DVI+ displayport + d-sub + 4x usb downstream hub ; 100x100mm vesa wall-mountable - 3 years warranty
2406 LG iPS226V-pn 22" Led display with iPS technology ( true 178° wide viweing angle + real color ) , 23mm slim , Full HD 1920x1080 (WUGA+) ; brightness- 250cd/m2 ; mega contrast ratio- 5000000:1 , response time- 8ms - d-sub+Dvi+HDMi+headphone out - 100x100mm vesa wall-mountable
3094 LG iPS236V-pn 23" Led display with iPS technology ( true 178° wide viweing angle + real color ) , 23mm slim , Full HD 1920x1080 (WUGA+) ; brightness- 250cd/m2 ; mega contrast ratio- 5000000:1 , response time- 8ms - d-sub+Dvi+HDMi+headphone out - 100x100mm vesa wall-mountable
