Netgear VEVG2660 PPPOE question
Thor
Bellville
I saw this on my Netgear modem:
Does that mean I can load up all 6 different ADSL accounts I have on one router?
How does one go about loading multiple ADSL accounts on 1 modem with 1 VDSL line? Is that possible?
First prize would be:
PS4 and Xbox use ISP-1 (WAN1 PPPOE)
Laptops use ISP-2 (WAN2 PPPOE)
Desktops use ISP-3 (WAN3 PPPOE)
Wifi use ISP-4 (WAN4 PPPOE)
It allows you to preconfigure several accounts you can switch between or use as fallback between fibre, dsl & 3g
Cant get it to work.
Only WAN1 works.
So you saying those different accounts will only work when the one above doesnt? So purely fallback? No PPPOE passthrough that i can set per lan port?
Lan port 1 = WAN1
Lan port 2 = WAN2
etc?
Any VDSL router that can do that?
No. you need to switch between them and apply thettings. Wan1-n is for different pppoe dialers and not associated with the lan port. each manufacturer is different so best to check their documentation. On my zyxel I need to manually ad a new wan interface and set it as active.
Its a bit off topic, apologies.
I just bought this router second hand to use with VOX FTTH. For some reason the LAN does not discover when I plug in my laptop, but I can connect wirelessly to the modem. Am I missing something here? I cant make heads or tails of it.
