Posted by: Denon101
Description: Better wireless speeds and range to surf and emailExtends your network coverage up to 4x more than Wireless-G†Easy set up with Smart Wizard® installation softwareAdvanced Speed and Range Better wireless speeds and range to surf and email Extends your network coverage up to 4x more than Wireless-G† Easy set up with Smart Wizard® installation software Maximum performance requires use with NETGEAR Super-G Wireless Router Features Delivers consistent wireless connections—no more dropped connections or dead spots Provides enough bandwidth to support file sharing and multimedia applications† Backward compatible with Wireless-G standard products Designed for your notebook PC Supports Windows® Vista™ Physical Specifications Dimensions (l x w x h): 4.68 x 2.12 x .25 in (119 x 54 x 6 mm ) Weight: 1.6 oz (46 g) Radio Data Rate 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, 54 Mbps and 108 Mbps in turbo mode (auto-rate capable)
More information about this product
