SirFooK'nG
Please help me solve my network issue...
I just extended my network cabling at home a bit, all is 10/100mbit (no gigabit). Goes like this...
Middle of house = Telephone line & ADSL router (Netgear) Wireless is enabled no problems there
Lounge HTPC to Router works fine.(Wired - 568A both ends)
PC Room CNET 5 port switch to Router works fine. (Wired - 568B both ends)
PC1 to CNET 5 Port works fine (Wired 568B both ends)
PC1 to Router works fine, PC1 to HTPC works fine)
PC Room CNET 5 Port switch to bedroom 5 Port Netgear switch (problematic) Wired 568A both ends
Zotac Mag to 5 Port Netgear (works fine - 568A both ends)
LG BluRay HET to 5 Port Netgear (works fine - 568A both ends)
PC2 to 5 Port Netgear (works fine - 568A both ends)
Zotac, LG HET & PC2 communicate at full speed no problem. but as soon as I try access anything past the Netgear switch to the CNET switch (internet, PC1 or HTPC) I get pathetic transfer rates and ping losses. All my cable is Cat5e and brand new.
So i know my issue is between CNET & Netgear switches. To the best of my knowledge, mixing 568A with 568B cables will work fine as long as both ends are the same (no crossover or using 568A on one end and 568B on the other). If I am wrong, please tell me. Also there shouldnt be an issue with two switches linke to each other??(getting a little past my home networking skills) if not, logically it is my cable thats faulty, pinouts are correct (quadripple checked)...
Any help ....
Any help ....
