Dark Agent
- Nov 30, 2008
How to make a network drive letter from E change to F?
Auto Run is E?
And Removable Disk is F?
I don't understand what is wrong...
If you go onto your desktop right click on my computer and click manage then disk management then right click the disk (the blue part) and say change drive letter and paths...
I want it on the slave also..
the master PC is right but the slave must change as the master settings
so now if i understand you correctly you are trying to change the autorun (F: ) to Autorun (E: )
And Removable Disk (G: ) to Removable Disk(F: )
Am i understanding correctly?
Okay so then you goto on the desktop my computer right click, manage, then select Disk management, select the Autorun (f: ) right click on the blue and say change drive letter or paths and change it to (H
Now select Removable Disk (G: ) and right click on the blue and select change drive letter and paths and change it to (F: )
The reason why you have to change both is because otherwise you won't be able to change Removable disc to F if F is already assigned a drive
