Hi
This is for a store.
Need some advise regarding which switches to purchase. I need 2 Gigabit 16 port switches. Unmanaged, but needs to be robust and have high availability. Which brands/models would you recommend. Also, what type of cable would you recommend. Minimum Cat 5e. Would Cat 6 be overkill?
There will be IP camera's running on the Back Office PC. Around 8.
My 2 PC Builds:
Thanks!
My 2 PC Builds:
Thanks!
