Nikon D3200 auto ISO?
bwana
MyBroadband
Super Moderator
Plz
Can a D3200 owner tell me how to enable Auto ISO on this piece of excrement?
Probably the same as mine - in the shooting menu - ISO sensitivity settings - auto iso on/off
Thanks for the reply - when I get there it says "This option is not available at current settings or in the camera's current state" :confused: Does that mean there's no auto ISO for Manual/Shutter/Aperture/Program modes?
Doesn't make sense...... with auto ISO off or on... i can go to m/a/s or p & access it in the menu to turn it off or on.
Your not sitting in Auto cos it won't let you at it then?
Grrrrrr.
Bladdy Nikon. :p
I've currently got it set on Aperture priority and I have to manually set the ISO.
Grrrrrr.
Bladdy Nikon. :p
with "i" pressed its not showing "ISO A" in the ISO dial? never mind what it says below
Menu/shooting menu/ISO sensitivity settings/Auto ISO sensitivity control - turn it on there, not the tab above it as that will give you the error you posted before.
Thanks - I'll have a look when I get back home. :)
Woah a second there. I'm just setting it up for a friend of my wife's. Right now it's cowering next to my 1Dx feeling very inadequate... as it should be. :P
Phew! I was worried there for a moment that your last your mind. :p
Bwana.... throw that piece of "excrement" away and stick to your trusty Canons.
