Nokia Wireless GPS Module LD-3W
rpm
Admin
Staff member
Johannesburg
by: eblshnnb
Description: Nokia Bluetooth GPS receiverGet where you're going with the Nokia Wireless GPS Module LD-3W.The Nokia Wireless GPS Module LD-3W connects to a compatible phone, PC, or PDA using Bluetooth wireless technology, and works with a number of different applications.Small and lightweightConnects wirelessly to a compatible phone, PC, or PDA using Bluetooth wireless technologyLEDs indicate power, status of Bluetooth wireless connection, and GPS statusUses a Nokia battery (rechargeable with compatible Nokia chargers)Minimum operating time 15h*, standby time up to 7 days*Battery status and other information is visible on the mobile phone display when the application used supports S60 v.3.0Compatible with a number of location-based applications and servicesVelcro sticker included to easily mount the GPS receiver on any part of your car Works with almost any phone that support Java.
