not registered on network
frans11
Dipkloof
hi there i have ported from mtn to cell , i am experiecing "not registered on network" sometimes it works ,
sometimes it doesnt , please help
HI frans11, Please PM me the number. Will check if everything is provisioned correctly. *DM*
still persists ....eish :(
Hi Frans, Please try doing a manual network selection from Vodocam to CellC to book line on the network. Otherwise everything is correctly provisioned on our side. *DM*
Hello Cell_C, could you please help me with this?
"I have a Samsung Trend Neo. I had an Android update recently. Now the phone drops its connection to Cell C regularly, resulting in missed calls, SMSs and Whatsapp messages. When I check using Settings, More Networks, Mobile Networks Cell C is not shown. When I select Network Operators and then select Cell C, the phone shows "Registering" and then "Registered" on Cell C, indicating that it had somehow become unregistered on Cell C. The phone then works for a while afterwards. Alternatively, if I restart the phone it works correctly for a while. The previous time I had this problem it was solved by buying a new Sim card and then getting Cell C to link it to my number.
What's happening? How can I ensure that the phone does not lose registration?"
Hi Dinks
Thank you for posting to us.
What colour is your SIM card? Are you using the blue LTE SIM card?
^BM
