supersunbird
So I had this A64 2800+ lying around, then I got a R400 motherboard for it.
So I ripped out my mothers PC's Celeron D 2.13GHz with its whiny high pitched little fan and the mobo and replaced it with the 2800+, enabling Cool&Quiet and the Smart Fan Monitoring in the BIOS thats makes the fan spin faster the hotter it gets, but real slow otherwise.
And now the machine downclocks itself to 1GHz and 1.09V when its not used (basically when its has done opening a program), and its almost totally quiet ALL the time. You can just just hear the AOpen case's powersupply fan spinning. The stock heatsinks 6cm fan also spins but so slowly its inaudable.
Since Cool&Quiet doesnt work well with overclocking and gaming I never enabled it on my rig. I'm impressed by this technology, as well as the quality and value of the Foxconn motherboard.
Anyone else like using it?
Edit: Need to get some quiet Zalman GPU cooler for my unlocked 6800le, the stock one is a whiny little biatch, especially on start up.
