Oil drop
Azbubu
Kapkaupunki
I bought some of this Sunfoil oil, to support the proteas, but I'm finding it impossible to use without it dripping along the bottle after pouring. I've tried using the provided cap but that doesn't help much either. Is there some sort of contraption to be used?
maybe use a funnel?
I was thinking maybe a straw, suck a little bit, hold the tip, then release.
Ok that sounds dirty.
Pour directly into mouth.
Don't suck it.
Just dip the straw into the bottle, hold the tip...transfer.
Buy a bottle of expensive olive oil, the ones where it has the plastic nozzle under the lid. Pour the olive oil down the drain and fill the bottle up with your cheap Sunfoil oil.
Works a treat....
like a pippette?
I normally just poke holes in the lid with a fork then pour through those holes.
.... I'm finding it impossible to use without it dripping along the bottle after pouring. I've tried using the provided cap but that doesn't help much either. Is there some sort of contraption to be used?
I feel your pain. I'm in my mid-60s and I just put it down to incontinence as one ages.
Hold it sideways so when you pour it it comes out the "side" of the hole and not the front or back.(Like when you pour water from those huge jugs)
If that makes any sense
Side of the hole? Reminds me of this:
Will something like this not work? I use them for pouring oil from glass bottles.
