My connection fell to 40kbps from 450 kbps over the last 2 days. Tried my afrihost and webafrica prepaid unshaped accounts. Anyone else experiencing problems ?
Well this is my current ping to webafrica.co.za on the Olivedale exchange:
Reply from 196.220.58.66: bytes=32 time=97ms TTL=122
Reply from 196.220.58.66: bytes=32 time=573ms TTL=122
Request timed out.
Reply from 196.220.58.66: bytes=32 time=47ms TTL=122
Request timed out.
Reply from 196.220.58.66: bytes=32 time=39ms TTL=122
Request timed out.
Reply from 196.220.58.66: bytes=32 time=38ms TTL=122
Reply from 196.220.58.66: bytes=32 time=59ms TTL=122
Request timed out.
Request timed out.
Request timed out.
Reply from 196.220.58.66: bytes=32 time=76ms TTL=122
Reply from 196.220.58.66: bytes=32 time=57ms TTL=122
Reply from 196.220.58.66: bytes=32 time=79ms TTL=122
Reply from 196.220.58.66: bytes=32 time=46ms TTL=122
Reply from 196.220.58.66: bytes=32 time=41ms TTL=122
Request timed out.
Request timed out.
Reply from 196.220.58.66: bytes=32 time=40ms TTL=122
Reply from 196.220.58.66: bytes=32 time=66ms TTL=122
Reply from 196.220.58.66: bytes=32 time=88ms TTL=122
Request timed out.
Reply from 196.220.58.66: bytes=32 time=72ms TTL=122
Request timed out.
Request timed out.
Been complaining for weeks now... some nights it works perfectly (Last night until 23:00 for example)... but more often than not it looks like above...
I am obviously being ignored / handled by my isp and telkom apparently has a backlog....
Is there anyone else having issues in Olivedale?.... I have tried, Axxess and webafrica... no difference... netgear and billion routers..
my current stats from my router:
Upstream 512 kbps
Downstream 4096 kbps
SNR Margin (Upstream) 16.0 db
SNR Margin (Downstream) 23.5 db
Line Attenuation (Upstream) 3.5 db
Line Attenuation (Downstream) 8.0 db
