Opel Astra G starting problems - somebody help
Apparently the throttle position sensor can be the cause, but try the other suggestions first.
Looks like someone is not paying the bills.
I have astra g 18 16v it don't wana kick there's no spark and injectors are ain't spraying any how pls help iv tried to check my switches no change
It would be an unfortunate coincidence if it were to happen that there's a problem with the electrical system and fuel injection, I suspect a case of over diagnosis which is when a DIYer diagnoses even perfectly functioning components as faulty. Don't fiddle too much with it if you've hit a brick wall, it's better to take it in to an electrician or mechanic.
