Good Evening
I had to replace the battery on my 2007 Opel Corsa lite sport early last week and since the installation the car has developed serious power issues. The car was serviced in October 2016 and was running perfectly up until the new battery was installed. The HT leads and coil pack all test in a good range but acceleration is a struggle, especially if I have to start on an incline. The revs drop to below 500 if my foot is not on the accelerator and drop almost to zero if I bring the car to a stop. At this point, the car shudders before the revs return to between 500 and 1000. I have unplugged the throttle sensor at times which alleviates the low revs but the power is still very low.
Any help on what may be the cause and why it only started after replacing the battery will be greatly appreciated.
Thanks.
Thanks.
