Oracle DB Issue
dubious
PTA
Good day all
I'm having a bit of a weird issue with an application I work with. It's a web based app that works with databases to store inventories of various things to do with buildings. On this particular project Oracle is being used. I tried deleting a record from the DB but when I log into the web app it still displays the record. It's as though there is a duplicated database however when I open up SQLDBX, there is only one database (or schema as I believe it's called in Oracle). I'm not a database guru at all with just basic understanding.
The set up is on a test sort of system running Oracle XE. Are there any suggestions or thoughts on how I can determine if there is in fact a duplicated schema and how I go about getting rid of it?
I hope someone can make sense of this because I'm actually not sure at all what the heck is going on...
Thanks in advance.
False alarm. We weren't commiting the delete so that's why it was still showing up.
