OVHD Decoder Info Bar
NevilleTheDevil!
Hi Guys,
Can anybody offer an explanation for above on the Ellies OVHD decoder Info Bar?
Especially the percentage and signal bars shown?
Thanks!
GoB
I think the bars are a static image because mine are the same.
Or its signal strength then quality, mine is about the same with a 60cm dish 80% / 51%
Digitaluser
Hi Guys,
Thanks!
It is signal strength and quality - mine is about the same - Are you getting all 19 channels - I am getting only 15 channels - the new added channels just show "No signal". I have tried a rescan :(
Captain Beer
Out of interest, does the info bar display the full channel name and is it just now and next info or does it show programs for the next few hours?
GoB
My new channels appeared automatically, I never rescanned.. but I don't think you want those channels.
You can scroll through the info for the next few days.
More useful is a function which displays a schedule of all channels. You can scroll through it and set reminders. The current channel will still play in the corner. That helps because you can check all programs for the day at a glance.
