Pally tank question
Huard
Since I can not seem to get my hunters DPS up to were I want it I will play with my pally tank. I have been working with him and know I need to get from Cenarion Expedition the necklace "Strength of the Untamed".
My question is what should I work on next, just got my Kara key so hopefully I will start off tanking there soon.
http://www.wowarmory.com/character-s...remyst&n=Strongarm
Thanks in advance
Huard/Strongarm
-.- I hate hunters... lol
We have some very nice Tankadins in our guild. Will get their armoury links for you and post it here tonight when I get home :) (can't access WoW site from work :p )
It's cause I play a wierd ass hybrid, have gone through the theorycrafting and improved my dps to an extent, but there is no way with my current build I will top the dps meters.
I can cc multiple targets though and do on occasion win Omen
If you not yet doing heroics for badges then felsteel gloves, legs and helm, or legs from caverns of time QM, and a def glyph from there for helm, Aldor QM has a chest with huge def rating and other aldor vendor in bank for shoulder glyph.
Wow, quitting because of that seems abit weak tbh.
Not really quitting my hunter, just taking a break until I can figure out how to get above total DPS as per recount of 560 for Kara up to the Curator. I know I should be higher then that and I "hate" being behind the rogues!
On the pally, I have the felsteel gloves and helm, the chest from aldor and the shoulder enhancement. I have the COT legging and helm enchancement also with the PvP mace. My def is 499 but SD is only 336. My uncrushable is only 89%. Think I need to increase my block value to increase threat and better SD gear. The question is what gear? Is there any BOJ gear I should go for?
If that link didn't work for my profile take a look at www.wow-heroes.com, Strongarm, Azuremyst, US server.
Since I am at work, I can only go to a few sites that are not blocked. Will look you up when i get home.
Doing some research it appears I should get "Badge libram" as soon as possible, do you agree?
