Well I'm leveling a pally but seeing as though how easy as hell they're at leveling I assume the feeble minded play them, and because you don't have enough brain cells to remember whole words, I have to assume that's why you play a pally, to faceroll and win. For the horde?
I am sorry, you need a spell rotation since the righteous fury nerf to hold aggro...?
Really you just spam abilities that are not on cooldown and you will hold aggro just fine. However it does make life easier to macro your 6 second and 9 second spells, so that you have 2 buttons and just press 6-9-6-9-6-9-6-9 and then use the other non-6/9 second abilities inbetween as needed.
As for which seal to use, for tanking Seal of Corruption is the best, especially on single target mobs, but even when I tank multiple mobs I really dont need anything else.
