palm treo pro - edge connection only
Grant
just around the corner
was digging thru a collection of old phones the other day trying to find a particular phone number.
found it on a plam treo pro !
out of boredom was fiddling around with it.
i discovered it will only connect to internet on cell c using edge.
put mtn & vodacom cards in it, & connects to both of them using 3G or HSDPA.
have tried changing network & band settings manually without luck.
called cell c, the call centre dolly told me their network does not support the phone ????
anyone know of a "work around" ?
it runs windows mobile 6.1
CellC uses 900UMTS band for 3G - the ph have that band?
The others use 2100...maybe your answer
*Edit* - maybe not if this is correct - http://www.gsmarena.com/palm_treo_pro-2494.php
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 1900 / 2100
SIM Mini-SIM
Announced 2008, August. Released 2008, October
Status Discontinued
if one goes to manual setup there are 2 options:
1 "network type" :
a) auto
b) gsm
c) umts
2 "band" :
a) auto
b) gsm (900 + 1800) + umts (2100)
c) gsm (850 + 1900) + umts (850 + 1900)
i have tried every combination including manually selecting network operator.
Yes it has no 900 UMTS to give you 3G on CellC but can give you 2G/Edge from i think the GSM1800
