Paradox Magellon 5050 wireless PIR issue
Perrie
I started renting a flat which has a very basic system consisting of an 5050 panel, wired keypad, 4x wireless PMD2 PIRs and a wireless siren which hasn't been used in years. I started by replacing the batteries of the PIR, updating the firmware and resetting the panel, and reprogramming the codes of the individual PIRs. They are registering movement as indicated by their LED's but for the life of me the system doesn't want to show any movement from them.
I have tried:
- resetting the panel again
- registering an PIR via the wired keypad by triggering the tamper on the PIR and the panel registered the code itself telling me there is communication between the panel and the PIR.
Its supposed to be an easy setup of wireless PIR's, I have done this on an other system and it worked without issue.
Has anybody maybe experienced this before?
I have tried:
Via Babyware? or panel.
If Babyware, don't forget to push your code changes up.
I do all my programming via babyware. changes where initially made on babyware and pushed to the panel. I have also tried the zone test feature on babyware but its not registering anything.
Babyware does also show the 4 PIR's being programmed.
