Hucklebury
- Aug 4, 2009
Hi there,
I recently had my PC upgraded, Haswell CPU with Asus motherboard (forgot the model, but it was very inexpensive).
Upon booting, the CPU fan moves a little, then stops, then moves a little, then stops, then moves full blast and makes a quite a loud noise for 4-5 seconds, then dies down and everything is normal.
So I thought that there might be a problem, but the guys from Chaos computers seem to think that this is normal behaviour. The cheaper motherboards exhibit this kind of 'problem'. Remember, this only happens when I boot my machine.
So I decided to pay a little more, get the new i5 6600 CPU with newer generation Gigabyte motherboard (not sure of the model, also very low cost (under R1000). The technician says the same thing is happening. That's it's all normal.
They showed me a PC in their shop using a much more expensive motherboard and the CPU fan operates normally from boot. So I don't know now if it really is a motherboard issue, because that would mean BOTH motherboards, even one generation apart, have the same issue.
What do you guys think? Should the fan be operating the way I've described and is that normal? It's just annoying to hear the fan ramp up into overdrive for several seconds each time the machine is booted. I don't remember this happening on my previous PC build, nor the PC fan behaving strangely on boot.
