PC not booting until I re-plug 24 pin connector
liambotha
My PC has starting to randomly cut power while playing games. When i reboot the PC only the PSU fans spin the rest is dead and wont boot until i have re-plugged the 24 pin connector on the motherboard. I have tried removing certain components but still gives the same problem. Any ideas what part could be causing the problem? Thanks
PC:PSU: Corsair GS800
RAM: 2x 4GB DDR3 Corsair Dominator Platinum
SSD: 256GB Samsung EVO
MB: Z87 ASrock Pro 4
GPU: GTX 970 gigabyte
CPU: i5 4670k
CPU: i5 4670k
when you start up go in to the bios and check the voltages see if they are stable
CPU Input Voltage: +1.744v
Vcore: +0.946v
+12.00v: +12.249v
+5.00v: +5.112v
+3.30v: +3.376v
Not sure what they should be. Thanks for the reply.
My money would be on the PSU being faulty. I had exactly the same issue some years ago.
It's probably not as random as you think. It'll happen when there's high load on both the CPU/GPU etc.
I can't say that's the cause beyond any doubt, but getting hold of and trying another PSU is definitely going to have to be your next step.
Thanks for the advice will try a new PSU and ill post the results!
