Hi all
My Pc has an issue,a day ago out of the blue it would not power on I tried everything,checked the plug and changed the plug. I check the psu cables,motherboard 24pin aswell and nothing. I pushed the button like 20times or so then it started. I shut down my pc switched of the psu,turned it on and tried to turn on my pc and the same problem?had to push it 20 times or so. Now it seems to be ok for now.
Also the psu fan is not spinning when I turn on my pc it like hesiitates but doesn’t spin is that an issue or should it spin only when it reaches a high temperature?
I gamed for an hour or so and the fan still didn’t spin so I’m wondering if there is not sufficient power to through to all the components?
Off the topic it could be coincidence but two of my rgb components stopped working about two weeks ago,after a couple of times turning it on and off they worked but then stopped and started like they work when they want to. Could that be related like no power going through the Sata cables?
My psu is the Superflower SF-750F14P(WH) and I’ve had it for 9months.
Any help would be great thank you
