Bought a usb3 pci card a few months ago and decided to fit it tonight.
So installed it and on boot the pc powers up but is beeping every 4 seconds. It takes you to a blank screen with a white underscore and just sits there.
Unplugged the pci card and the computer is still doing the same thing.
What do i do? I am going to take out the memory modules one at a time and the the HDDs and see if this solves anything.
Any one got any ideas? This only started when i put the pci card in (Side note the card has a 4pin mole plug on it which I did plug into the power supply)
