seven7seven
- Oct 31, 2003
Hi all,
I've been using an old Pentium 1 box as a Wireless Access Point (using Pyramid Linux). It's been running fine 24/7 for about a year or so but a few weeks ago stopped booting.
Diagnosis so far:
Powers on, does POST, but then when it tries to boot off the harddrive it says:
"DISK BOOT FAILURE, REPLACE WITH SYSTEM DISK & HIT ENTER KEY".
I immediately suspected the harddrive had died, but after putting the drive into another PC it worked fine, so it's not the drive (or at least I don't see how it can be. I also tried booting off another hd, same result).
I tried with various IDE cables, nothing.
When I go into the "Auto IDE Detection" in the BIOS, it detects the drive just fine.
However, during the POST it lists the following:
"Primary Master Disk: none
Primary Slave Disk: CHS , Mode 0, 0MB. <--- pretty sure that's a bad sign."
Also, I tried to boot off a (bootable, I tested in another machine) stiffy disk, all I got was:
"Disk I/O Error - replace with system disk & try again". (dono if the floppy drive DOES work tho, so dono if this error is related...)
</diagnosis>
So... could this be a faulty motherboard or ?
I realise this is really obsolete hardware but this machine's got a lot of sentimental value to me: I've had it running headless as some sort of 'server' 24/7 for about 8 years or so, and would prefer not to just dump it
Your help is much appreciated to resurrect this old timer!
Richard
Diagnosis so far:
</diagnosis>
Richard
