spiff
- Oct 17, 2007
On one of my 2015 cnc wire cutting machines, there is a large pcb that has many multi-pin plugs "pressed" into the board and not soldered to the board. these multi-pin plugs are for the driver cards etc. (see pic below)
now this machine has been giving me endless trouble, like not booting up properly / losing voltage / not reading the driver cards / drives not working / not edge finding / running extremley slow etc. The machine supplier has no idea what the probem is and they have been swapping out driver cards for over a year now trying to "fault find" to no avail.
My concern is with all the movement of removing & re-installing cards into these unsoldered "pressed in" multi-plugs, surley this will cause more poor connections and worsen the problem?
anyone can advise me on why it was done this way?
is this just a cheap way to assemble the multi plugs to the pcb?
what can I do?
My gut feeling is to solder all the pins?
any advice will be appreciated
what can I do?
