Posted by: Neo-T
Description: For Sale Guys PCI 2X Serial Port Cards Bran New Still Sealed In Boxes 5 Available Sunix 4037 - 2 port serial ( 16c550 ) , 32/64bit 3.5/5V pci card , 32byte hardware 128k software FiFo, 921.6 Kbps , 32/64bit 3.5/5V pci card, ready for 64 bit system, WHQL certified Sunix universal PCI Multi-port serial card provides RS-232 Serial connection ports on your system for your application needs. The 4037 card series works on both 32-bit and 64-bit PCI Bus with 3.3V or 5V power, allowing this multi-port serial card to be installed in virtually any PC system and compatible with all major operating systems. The card supports multi independent RS-232 ports, with each port transfer data up to 921.6 Kbps. Sunix universal PCI Multi-port serial cards is the best solution for various industrial communication and automation applications. * Low RMA rate and high reliability with Sunix’s single chipset designed ASIC * Compliance with PCI ver. 2.2 spec. standard * Supports both 32 / 64-bit PCI slot with 3.3V / 5V bus power * Industrial grade design for stability and reliability * 128K FIFO buffer can reduce CPU loading, less interruption and improving system performance dramatically * Plug-n-Play, I/O address and IRQ assigned by BIOS * RS-232 industrial host controller series are certified by WHQL, CE, FCC approval * Support Microsoft Windows, Linux, and DOS
PCI-Serial Port Cards
