Photographic Studio (Basic set up)
Creag
The Boar's Rock
Joburg
I would like to set up a basic photographic studio. The subject of photography will be Lego sets. Nothing really big. Mostly objects that are about 15 - 30 cm in width and 30 - 25 cm in height.
The backdrop is to create ensure a "uniform" / smooth background - and something like this (might be slightly bigger than need):
- Floxi PVC vinyl backdrop + backdrop stands
The lighting needs to light up the subject adequately and eliminate shadows as much as possible. Something like this seems to generate good lighting:
- Photgraphic continuous photo video studio light kit - 1200W
Any recommendations or alternate ideas?
I have a similar light box to this :
Should be perfect for your requirements.
Foresight LED Photo Light Box - Studio Tent 60cm - 4th Generation available to buy online at @TAKEALOT We offer fast, reliable delivery to your door.
Also using a light tent for this size of object, usually illuminated by a flash. This gives good overall lighting.
This works well for small objects.
Lit with a bunch of inexpensive clip on lights with LED bulbs. For jobs like this I prefer continuous lighting - helps to avoid unnecessary specular highlights and eliminate any unwanted shadows.
FWIW a bath tub also works well.
