Buy a prepaid gaming system e.g. PS3, Xbox360, Nintendo Wii and have money for 5-6 games
Do they require a monitor? Hard drive etc? Or in other words, do they have a current machine with anything that is reusable?
They don't have anything that is reusable except for perhaps a monitor
This will be a bit challenging due to the fact that he needs EVERYTHING and the high cost of hdd's these days. Also if he intends to do the legal thing - that is buy Windows and Office - it will severely limit what he can afford. Without software here is one possible build:
Case: Zalman Z7 - r500
PSU - Corsair cx500 - r600
Ram - G.Skill 8gb 1600mhz - r500 (wootware)
Graphics - GTX560ti - r2200 (wootware)
CPU - AMD X6 1055t - r1400
Mobo - MSI 890GXM - r1100
HDD - 500gb - r700
TOTAL - r7000. As you said that's the high end of his budget.
BTW there is no crysis 3. Just FYI dude.
lmao cerebus !
i was going to post the same rig with a zalman z9 and cx600 and club3d 6850 XD SIGH
but with less ram , 4 or 6gb
IMO 8gb these days is critical. I couldn't believe the difference it made when I upgraded last month.
do you do coding or editing and stuffs ? my friendo does coding for a company using his own pc and he said from 6gb to 8gb there was no real difference, there should be a big difference from 4gb to 8gb + better timings from better quality ram that is
I run voice recognition apps and a number of other memory intensive programs at the same time. I find Win7 64 is around 2.5gb usage as a base, and then once you hit 3+gb pagefile usage it starts to chunk on 4gb.
