Hello everyone.
I will try to explain this as best as I can but if I leave anything out, please post questions.
I have the Neotel phone and the uncapped (R1000.00 per month) option. The phone, as you all probably know, is USB.
My idea was to connect the phone to the server (running Windows Server 2003 R2, setup for DNS and DHCP), share the neoconnect internet connection (I am not using the neoconnect manager), connect the server to a router/switch (NETGEAR WNR2000 V2 - 4 port ethernet, wireless and a WAN port) and then to connect 2 PC's, a NAS via ethernet and a laptop via wireless.
The laptop runs Windows XP SP3 (up to date, firewall is off)
The 2 PC's run Windows 7 Ultimate x64 (up to date, firewalls are off)
I've managed to make everything work for about 2 months ... give or take a day. Everything was running smoothly, the 2 PC's and laptop all had internet and my network worked like a charm. One day it all stopped:
* The server is the only machine on my network that has access to internet.
* The 2 PC's and laptop don't, but they all get their IP's and Gateways successfully from the server.
* Every computer can connect to the NAS and watch movies, listen to music and view share files and folders, but they just don't have internet access.
This is what I have done so far:
* I have disconnected my internet connection and taken Internet Connection Sharing off, then I went online and disconnected again.
* I then enabled my Internet Connection Sharing again and connected to the internet (same story, only the server had internet access)
* I have checked my Netgear and made sure that the IP is different to that of the server and that DHCP was disabled (I've pretty much made it into a wireless hub), saved all the settings and still nothing. Server is the only one with access to the internet.
PLEASE HELP! This is so frustrating. It all worked fine and then it stopped all of a sudden.
I'm sure I am overlooking something here but I just can't figure out what it is.
Oh yeah, I have the phone installed on all 4 USB ports and no matter which port I connect the phone on, same story.
All and any advice/help will be much appreciated.
Thank you.
Thank you.
