Once you let the smoke out they no longer work![]()
That's because all the magic is in the smoke!
Can you get YouTube?
[video=youtube;DV3eyb8qNbs]http://www.youtube.com/watch?v=DV3eyb8qNbs[/video]
Don't worry too much, in case you were more worried now because it broke the first time you used it. It's unlikely that handling normally with care (and not dropping it, etc.) and installing and connecting all connectors correctly would cause damage to a modern PSU.
What case have you got?
Yeah I am pretty nervous after the last ordeal. I have got a gigabyte case I will try to find model number, the psu slot is in the top.
Okay, then mount the PSU with its 120mm fan facing down. Try keep the cables neat, tie unused ones together to minimise obstruction of airflow.
I've been having probs with my pc and just tried my 450watt psu again with a n ew rig and it also tripped the electricity and now its dead. Can a faulty psu cause a mobo or cpu to go?
