Hey everyone,
I'm using (not very successfully) a Cell C prepaid on an Acer Aspire One's built-in 3G modem. I have three problems with it though:
1) The connection manager software that was pre-installed on the Acer (Globetrotter Connect "something or other") is VERY basic and I'm unable to top-up the databundle without having to remove the SIM, plug it into a phone, dial the *147* etc etc. I don't know what the Cell C connection manager is called so forgive me, but I'm looking for the connection manager which Cell C would recommend which will have all the bells and whistles and enable me to top-up, SMS, check the data transfer rates etc. that could work with the built-in modem as I've installed the software from a mates Speedstick but it wouldn't pick up the built-in modem (probably something I'm missing here though, so if anyone's got any suggestions I'm listening)
2) I can only pick up GPRS/EDGE with it....
Not sure if it's the SIM I'm using (which I bought at Pick 'n Pay, I think, about 4 months ago) or the modem.
3) When I'm at home (Westville, KZN) I cannot get any data transfer. I can connect to Cell C's network (again on the GPRS/EDGE network) but for the life of me I cannot browse. I receive on IP straight away but cannot PING the DNS servers and nothing will resolve. This is unrelated to either the slow connection or the connection manager as I can connect, albeit poorly, when I'm out of the area.
What I'd like to do is get the Speedstick package from Cell C which should solve the first two issues, but I'm unwilling at the moment as to sign a 12 month contract to use in an area where it won't work, as that's a waste of money!
Hope I posted this correctly?
Any help or suggestions welcome.
Thanks.
Thanks.
