GEE_911
Hi, i currently have a telkom ISDN 2a switchboard, and i am looking to upgrade to an ADSL line... Will the ADSL line still be able to work on an ISDN switchboard
while yes it is technically possible to run adsl on a switch board my experience says stay away. once u run into problems there is almost no way of figuring out where your problem is out 5 clients I have that have done this 1 is working that makes 2 out of 6 ppl (counting the person prev poster talked bout) thats 1 in 3 chance of working![]()
try it but be warned
i recommend rather a separate line for adsl
ADSL does not run on ISDN... your line will have to be moved back to a normal line and then be upgraded to ADSL
Sorry guys i made a mistake... its a Siemens ISDN Switchboard, but what your saying is that if i downgrade to a normal line, then upgrade it to ADSL will work fine?
