Plugged in two harddrives while PC was on.
  • Thread starter Thread starter Leonidas
  • Start date Start date
L
Leonidas
Guest
Master and slave.
But both are still working.
It was noisy in the background and my case is under my desk so it's dark. I didn't see or heard the PC was on.
I know it's not standard procedure to hot swap drives like this in a standard PC.
Why is my hard drives still working? Shouldn't they be fried.
OP is about ATAPI - master/slave.
Besides, SATA by default is not hot swappable. Connector is, but it requires extra support from the controller.
Master and Slave, those are terms I haven't heard in a while with regards to hard drives :p
OP are you using a SATA or IDE connector?
Okay, the one with the OS and the one without.
Those that aren't can still hotswap. Go to Device Manager and click "Scan for hardware changes"
