Plz help me(warcraft3)
EvilFoX
I need a programme that will help me change the key’s for my spells and abilities say I want spell 1 to be Q ,spell 2 W ,spell 3 E ,spell 4 R I know its out here plz give me a link to dl it from THaNX
Is there even such a program?
I'd think u can change it from WITHIN the game in the options menu or something.
lol every spel has his own key and options menu dont have key changer in it ,its like a banlist program works the same you run it then you run warcraft and yes there are but its not a thing you get with googleing
There's a text file in your warcraft 3 folder called customkeys.txt (IIRC), you can change all your key bindings in there.
U arent by any chance playing dota and want this? Cause i cant really see needing it for playing the Campaign? If u are needing it cause of dota then u can get a program called DotaKeys.
U arent by any chance playing dota and want this? Cause i cant really see needing it form playing the Campaign? If u are needing it cause of dota then u can get a program called DotaKeys.
thx that wht i needed so it works for dota only and where do i dl it from
O and is it legal ?
PS. do not update it makes a bobo:D
help if som1 gets it right ERROR
Check the war3.co.za forums you prob finf more help on it there. thts were i heard about it.
